IMPORTCREOCONFIGURATION system variable
Import Creo configuration
Specifies the name of the Creo configuration that should be imported. If no configuration name is specified, then the part's default configuration will be imported.
BricsCAD only
Type: |
String |
Saved in: |
Registry |
