IMPORTHIDDENPARTS system variable
Hidden parts
Defines the hidden parts processing mode.
Type: |
Short |
Saved in: |
Registry |
Range: |
0 to 2 |
Default value: |
0 |
Possible values: |
0: Import and hide: All entities are imported; invisible entities are hidden. Note that currently there are no user tools to make these hidden entities visible again. 1: Import and set visible: All entities are imported and visible, regardless of the visibility in the source file. 2: Do not import: Hidden entities in the source file are not imported. |
