IMPORTHIDDENPARTS system variable
Hidden parts
Defines the hidden parts processing mode.
Tipo: |
Breve |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 2 |
Valore predefinito: |
0 |
Valori possibili: |
0: Import and hide: All entities are imported; invisible entities are hidden. Note that currently there are no user tools to make these hidden entities visible again. 1: Import and set visible: All entities are imported and visible, regardless of the visibility in the source file. 2: Do not import: Hidden entities in the source file are not imported. |
