IMPORTHIDDENPARTS system variable
Hidden parts
Defines the hidden parts processing mode.
Type:
Short
Saved in:
Registry
Range:
0 to 2
Default value:
0
Possible values:
0: Import and hide: All entities are imported; invisible entities are hidden. Note that currently there are no user tools to make these hidden entities visible again.
1: Import and set visible: All entities are imported and visible, regardless of the visibility in the source file.
2: Do not import: Hidden entities in the source file are not imported.
