IMPORTSIMPLIFY system variable
Perform simplification
Enables automatic DMSIMPLIFY operation on imported model:
- Convert imported splines into canonical surfaces.
- Simplify topology (remove imprinted edges) if possible.
Note: Also check the IMPORTIGESSIMPLIFY setting, which can set an
override for the IGES file format.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: | 0 |
