IMPORTSIMPLIFY system variable
Perform simplification
Enables automatic DMSIMPLIFY operation on imported model:
  • Convert imported splines into canonical surfaces.
  • Simplify topology (remove imprinted edges) if possible.
Note: Also check the IMPORTIGESSIMPLIFY setting, which can set an override for the IGES file format.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value: 0
