IMPORTSOLIDWORKSCONFIGURATION system variable
Import SolidWorks configuration
Specifies the name of the SolidWorks configuration that should be imported. If no configuration name is specified, then the part's default configuration will be imported.
BricsCAD only
Type:
String
Saved in:
Registry
