INSBASE system variable
插入基准点
Stores the drawing's insertion point when inserted into other drawings. INSBASE is set by the BASE command and expressed as a UCS coordinate for the current space.
Type: |
3D point |
Saved in: | Drawing |
Default value: |
0,0,0 |
