INSUNITSSCALING system variable
Insertion units scaling
Specifies how INSUNITS scaling is applied when inserting, importing and pasting data.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 3
Default value:
1
Possible values:
1: Enable INSUNITS scaling. When inserting or attaching Xrefs, Blocks or images the inserted content is scaled with respect to the value of INSUNITS in the target and source drawing. If INSUNITS in the source drawing is Unspecified, INSUNITSDEFSOURCE is used instead. If INSUNITS in the target drawing is Unspecified, INSUNITSDEFTARGET is used instead.
2: Use paper size unit instead of INSUNITS for insertions in paper space.
