INTERFERENCELEVEL system variable
Interference Check Level
Controls the degree to which interferences between copied details and between details and the rest of the model are checked.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 3 |
Valore predefinito: | 0 |
Valori possibili: |
0: No interference checking 1: Check overlap of detail volumes 2: Full interference checking without considering background spatial elements 3:Full interference checking |
