INTERFERENCELEVEL system variable
Interference Check Level
Controls the degree to which interferences between copied details and between details and the rest of the model are checked.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 3
Default value: 0
Possible values:
0: No interference checking
1: Check overlap of detail volumes
2: Full interference checking without considering background spatial elements
3:Full interference checking
