INTERFERENCELEVEL system variable
Interference Check Level
Controls the degree to which interferences between copied details and between details and the rest of the model are checked.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 3 |
| Default value: | 0 |
| Possible values: |
0: No interference checking 1: Check overlap of detail volumes 2: Full interference checking without considering background spatial elements 3:Full interference checking |
