INTERSECTEDENTITIES system variable
Resolve intersection.
Determines how to modify entities that intersect with the extruded/revolved entity when the Auto option of the Extrude or Revolve command is selected.
BricsCAD only
Type:
Short
Saved in:
Workspace
Range:
0 to 2
Default value:
0 - for Workspaces Drafting and Modeling
1 - for Workspaces Mechanical and BIM
Possible options:
0: Do not modify the parent entity.
1: Subtract the created entity from the parent entity.
2: Unite the created entity with the parent entity.
