ISAVEBAK system variable
Incremental save backup
Specifies the creation of a backup file (BAK). Improves the speed of incremental saves if switched off, especially for large drawings.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t create BAK file
On (1): Create BAK file
