ISAVEBAK system variable
Incremental save backup
Specifies the creation of a backup file (BAK). Improves the speed of incremental saves if switched off, especially for large drawings.
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t create BAK file On (1): Create BAK file |
