LAYERFILTEREXCESS system variable
Layer Filter Excess
Specifies the maximum number of layer filters allowed in a drawing before suggesting some be removed. You can create any number of layer filters. However, if the number of layer filters exceeds this value and exceeds the number of layers, a message dialog displays the next time you open the drawing. It recommends deleting all layer filters to improve performance. When set to 0, the message is never displayed.
BricsCAD only
Type:
Short
Saved in:
Preference
Default value:
250
