LAYLOCKFADECTL system variable
锁护图层淡出控制
Specifies the fading level for entities on locked layers to contrast them with entities on unlocked layers and reduces the visual complexity of a drawing. Entities on locked layers are still visible for reference and for object snapping. Non-positive values disable fading.
Type: | Short |
Saved in: | Registry |
Range: |
-90 to 90 |
Default value: |
50 |
