LAYOUTREGENCTL system variable
布局重生控制
Specifies how the display of the Model tab and layout tabs is updated. If performance is poor in general or when switching between tabs, setting LAYOUTREGENCTL to 1 or 0 might improve performance.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 2 |
Default value: |
2 |
Possible values: |
0: Always regenerate 1: 抑制将“模型”或上个布局标签设为现行标签时重生 2: Regenerate first time only |
