LAYOUTREGENCTL system variable
Layout regeneration control
Specifies how the display of the Model tab and layout tabs is updated. If performance is poor in general or when switching between tabs, setting LAYOUTREGENCTL to 1 or 0 might improve performance.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 2 |
Default value: |
2 |
Possible values: |
0: Always regenerate 1: Suppress regeneration for Model tab and last layout made current 2: Regenerate first time only |
