LEGACYCODESEARCH system variable
遗留代码搜索模式
Specifies how BricsCAD searches for executable code in drawing folders.
只读
Type: | Boolean |
Saved in: | Not saved |
Default value: | Off |
Possible values: |
Off (0): Disable unsafe searching for executable code On (1): Enable unsafe searching for executable code |
