LICFLAGS system variable
Licensed components
Specifies whether certain components are licensed or not. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Read-only
Type:
Short
Saved in:
Not saved
Range:
0 to 7
Default value:
0
Possible options:
0: No components licensed
1: VBA is licensed
2: Acis editing is licensed
4: Pro
