LINEARBRIGHTNESS system variable
视口亮度
Specifies a scaling factor for the intensity of lights. A value between -10 and 10 is accepted. The default value of 0 results in no scaling. Smaller values decrease light intensity and bigger values increase light intensity. This setting can be specified per viewport.
Type:
Short
Saved in:
Drawing
Range:
-10 to 10
Default value:
0
