LINEARCONTRAST system variable
视口对比度
Specifies ambient light intensity. A value between -10 and 10 is accepted. A value of -10 results in maximum ambient light. A value of 10 results in no ambient light. This setting only has effect on materials that have a non-black ambient color. This setting can be specified per viewport.
Type: | Short |
Saved in: | Drawing |
Range: |
-10 to 10 |
Default value: |
0 |
