LOADMECHANICAL2D system variable
Mechanical 2D enablers
Specifies whether or not demand loading of Mechanical 2D enablers is permitted.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Loading of Mechanical 2D enablers is not permitted
On (1): Loading of Mechanical 2D enablers is permitted
Note: Changing the value of this variable will take effect after restarting the application.
