LOCKUI system variable
Lock user interface elements
Specifies which user interface elements are locked to prevent accidental dragging. To override press the Ctrl (Windows) or Cmd (Mac) key while dragging. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short  |
| Saved in: | Registry  |
| Range: |
                            -7 to 7  |
| Default value: |
                            0  |
| Possible options: |
                            1: Lock docked toolbars 2: Lock docked panels 4: Lock floating panels and toolbars  |
