LOFTNORMALS system variable
Loft normals
Specifies the normals of lofted entities as they pass through cross sections.
Tipo: | Breve |
Salvato in: | Disegno |
Gamma: |
0 to 6 |
Valore predefinito: |
1 |
Valori possibili: |
0: Ruled surface 1: Smooth surface 2: Surface is normal to the first cross section 3: Surface is normal to the last cross section 4: Surface is normal to the first and last cross sections 5: Surface is normal to all cross sections 6: Surface uses draft angle and magnitude |
