LOFTPARAM system variable
放样参数
Specifies the shape of lofted surfaces and solids. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Drawing |
Range: |
0 to 15 |
Default value: |
7 |
Possible options: |
0: No parameters 1: No twist between cross sections 2: Align directions of cross sections 4: Create simple surfaces and solids 8: Close between the starting and ending cross sections |
