LOFTPARAM system variable
Loft param
Specifies the shape of lofted surfaces and solids. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Drawing
Range:
0 to 15
Default value:
7
Possible options:
0: No parameters
1: No twist between cross sections
2: Align directions of cross sections
4: Create simple surfaces and solids
8: Close between the starting and ending cross sections
