LOGFILEMODE system variable
Log file mode
Specifies whether a logfile is maintained or not. A logfile contains each executed command. These logfiles are saved in the folder specified by the LOGFILEPATH system variable.
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Don’t maintain log file
On (1): Maintain log file
