LOGFILEMODE system variable
Log file mode
Specifies whether a logfile is maintained or not. A logfile contains each executed command. These logfiles are saved in the folder specified by the LOGFILEPATH system variable.
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Don’t maintain log file On (1): Maintain log file |
