LOOKFROMDIRECTIONMODE system variable
LookFrom 方向模式
Specifies how many view directions can be selected in isometric mode. Holding the Ctrl (Windows) or Cmd (Mac) key switches from top-down to bottom-up directions.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 3 |
Default value: |
1 |
Possible values: |
0: 仅正交 (6个方向) 1: 边没有平的视图 (14个方向) 2: 顶/底4等角及边 (18个方向) 3: 8上/下转角(26方向) |
