LOOKFROMDIRECTIONMODE system variable
LookFrom direction mode
Specifies how many view directions can be selected in isometric mode. Holding the Ctrl (Windows) or Cmd (Mac) key switches from top-down to bottom-up directions.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 3 |
Default value: |
1 |
Possible values: |
0: orthogonal only (6 directions) 1: no flat view at corners (14 directions) 2: 4 top/down corners(18 directions) 3: 8 top/down corners(26 directions) |
