LTGAPSELECTION system variable
Linetype gap selection
Specifies whether selection or snapping to the gaps on entities defined with non-continuous linetype is possible.
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Gamma: | OFF |
Valori possibili: |
Off (0): No selection or snapping within gaps (legacy behavior) On (1): Selection or snapping within gaps |
