LTGAPSELECTION system variable
Linetype gap selection
Specifies whether selection or snapping to the gaps on entities defined with non-continuous linetype is possible.
Type:
Boolean
Saved in:
Registry
Range:
Off
Possible values:
Off (0): No selection or snapping within gaps (legacy behavior)
On (1): Selection or snapping within gaps
