LWDEFAULT system variable
Default lineweight
Specifies the default lineweight (in hundredths of millimeters).
Type:
Short
Saved in:
Registry
Range:
0 to 211
Default value:
25
Possible values:
-3: Default (defined by LWDEFAULT)
-2: ByBlock
-1: ByLayer
0 - 211: Lineweight value in hundredths of millimeters
