LWDEFAULT system variable
默认线宽
Specifies the default lineweight (in hundredths of millimeters).
Type: |
Short |
Saved in: |
Registry |
Range: |
0 to 211 |
Default value: |
25 |
Possible values: |
-3: Default (defined by LWDEFAULT) -2: ByBlock -1: ByLayer 0 - 211: Lineweight value in hundredths of millimeters |
