MASSPREC system variable
Mass precision
Specifies the number of decimal places displayed for masses when the mass bit of PROPUNITS is on. If negative, LUPREC (Linear Unit Precision) is used.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Registro di sistema |
Gamma: |
-1 to 8 |
Valore predefinito: |
-1 |
Valori possibili: |
-1: Use LUPREC 0: 0 1: 0.0 2: 0.00 3: 0.000 4: 0.0000 5: 0.00000 6: 0.000000 7: 0.0000000 8: 0.00000000 |
