MASSPROPACCURACY system variable
Mass properties calculation relative accuracy
Specifies the accuracy to be used for mass properties calculations. This accuracy is relative: the accuracy of the result depends on the magnitude of the calculated value. Acceptable value Range: 2 - 12 (0.01 to 0.000000000001, or 1.e-2 to 1.e-12).
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
2 to 12
Default value:
2
Possible values:
2: 0.01
3: 0.001
4: 0.0001
5: 0.00001
6: 0.000001
7: 0.0000001
8: 0.00000001
9: 0.000000001
10: 0.0000000001
11: 0.00000000001
12: 0.000000000001
