MAXTHREADS system variable
最大线程数
Specifies the maximum number of threads used for display and loading of drawings, in case one of the Multi-Threading flags has been set. Value 0 means the program will choose the optimal number of threads.
BricsCAD only
Type: | Short |
Saved in: | Registry |
Range: |
0 to 16 |
Default value: |
0 |
