MAXTHREADS system variable
Maximum number of threads
Specifies the maximum number of threads used for display and loading of drawings, in case one of the Multi-Threading flags has been set. Value 0 means the program will choose the optimal number of threads.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 16 |
| Default value: |
0 |
