MEASUREINIT system variable
度量初始
Specifies drawing units as Imperial or metric for new drawings. It also controls whether ANSI or ISO hatch pattern and linetype files are used.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 1 |
Default value: |
1 |
Possible values: |
0: Imperial (use ANSI Hatch and ANSI Linetype) 1: Metric (use ISO Hatch and ISO Linetype) |
