MEASUREINIT system variable
Measurement initial
Specifies drawing units as Imperial or metric for new drawings. It also controls whether ANSI or ISO hatch pattern and linetype files are used.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible values: |
0: Imperial (use ANSI Hatch and ANSI Linetype) 1: Metric (use ISO Hatch and ISO Linetype) |
