MECHANICALBLOCKS system variable
Mechanical blocks (experimental)
Enables or disables mechanical blocks (experimental feature) as an alternative to mechanical components.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Off (0): Disables mechanical blocks
On (1): Enables mechanical blocks
