MSOLESCALE system variable
模型空间 OLE 对象尺寸
Specifies the size of an OLE (Object Linking & Embedding) object containing text when pasted into model space. This only affects the initial size, entities already placed in the drawing are not affected when MSOLESCALE is modified. If set to zero, scales by DIMSCALE value.
Type: | Real |
Saved in: | Drawing |
Range: |
0.0 or greater |
Default value: |
1.0 |
