MTEXTFIXED system variable
Multiline text fixed
Specifies whether BricsCAD zooms, rotates and/or pans the view to fit the multiline text being edited.
Type:
Short
Saved in:
Registry
Range:
0 to 2
Default value:
2
Possible values:
0: Do nothing when mtext editor is opened
1: Do nothing when mtext editor is opened
2: Rotate / zoom / pan view to fit multiline text
