MTFLAGS system variable
Multi-Threading Flags
Bit flags for parallel processing of display and loading. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Registry
Range:
0 to 511
Default value:
960
Possible options:
1: Parallelized regeneration of display.
2: Parallelized redraw of display.
4: Parallelized loading of drawings.
8: Parallelized calculation of hidden line removal.
16: Parallelized generation of BIM sections to separate destination files.
32: Parallelized generation of BIM sections to the same destination file.
64: Parallelized computations in Direct Modeling commands and operations.
128: Parallelized computations in Assembly commands and operations.
256: Parallelized computations in Sheet Metal commands and operations.
512: Parallelized interference checking
1024: Delayed XREF loading
