MULTISELECTANGULARTOLERANCE system variable
BimMultiSelect angular tolerance
Specifies the maximum angle between two linear solids' axes at which these solids are still considered parallel.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 90 |
Valore predefinito: | 3 |
