MULTISELECTANGULARTOLERANCE system variable
BimMultiSelect angular tolerance
Specifies the maximum angle between two linear solids' axes at which these solids are still considered parallel.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 90 |
| Default value: | 3 |
