NEARESTDISTANCE system variable
Nearest Distance
Specifies nearest distance dimension between pair of selected entities. The value is stored as a bitcode using the sum of the values of all selected options.
Solo-BricsCAD
Tipo:
Breve
Salvato in:
Registro di sistema
Gamma:
0 to 15
Valore predefinito:
1
Possibili opzioni:
1: Show nearest distance dimension
2: Show OX aligned nearest distance dimension
4: Show OY aligned nearest distance dimension
8: Show OZ aligned nearest distance dimension
