OBJECTISOLATIONMODE system variable
Object Isolation Mode
Specifies whether entities that are temporarily hidden with HIDEOBJECTS or ISOLATEOBJECTS remain hidden after saving and reopening the drawing.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: |
0 to 3 |
Valore predefinito: |
0 |
Valori possibili: |
0: Entities are temporarily hidden for the current session. Interfered solids are selected together with the interference solids. 1: Entities remain hidden between sessions. Interfered solids are selected together with the interference solids. 2: Entities are temporarily hidden for the current session. Interfered solids are not selected together with the interference solids. 3: Entities remain hidden between sessions. Interfered solids are not selected together with the interference solids. |
